주요 콘텐츠로 건너뛰기
Asus X401A Hard Drive Replacement
필요한 것
  1. Asus X401A Hard Drive Replacement, Remove Screws: 1 단계, 이미지 1/1
    • Turn laptop over on flat, stable surface.
    • Remove 8 Phillips Screws
  2. Asus X401A Hard Drive Replacement, Remove Battery: 2 단계, 이미지 1/3 Asus X401A Hard Drive Replacement, Remove Battery: 2 단계, 이미지 2/3 Asus X401A Hard Drive Replacement, Remove Battery: 2 단계, 이미지 3/3
    • Slide battery lock to unlocked position on left side, then hold it in on the right side while sliding the battery out.
  3. Asus X401A Hard Drive Replacement, Remove more screws: 3 단계, 이미지 1/1
    • Under the battery are 2 hidden screws, time for them to go.
  4. Asus X401A Hard Drive Replacement, Take apart housing: 4 단계, 이미지 1/3 Asus X401A Hard Drive Replacement, Take apart housing: 4 단계, 이미지 2/3 Asus X401A Hard Drive Replacement, Take apart housing: 4 단계, 이미지 3/3
    • Turn over laptop
    • Open lid as far as it will go
    • Insert opening pick as shown
    • Follow entirely around the laptop
    • On the underside of the keyboard are 2 flat cables, please see next step before proceeding!
  5. Asus X401A Hard Drive Replacement, Flat cables: 5 단계, 이미지 1/2 Asus X401A Hard Drive Replacement, Flat cables: 5 단계, 이미지 2/2
    • On the underside of the keyboard are 2 flat cables connected to the surface.
    • You can use a opening pick to pop these out of their respective slots on the main board.
  6. Asus X401A Hard Drive Replacement, Flat cable over hard drive: 6 단계, 이미지 1/3 Asus X401A Hard Drive Replacement, Flat cable over hard drive: 6 단계, 이미지 2/3 Asus X401A Hard Drive Replacement, Flat cable over hard drive: 6 단계, 이미지 3/3
    • Using an opening pick you can now undo the connector for over the hard drive.
    • There is adhesive holding the flat cable to the hard drive.
    • Slide something under the flat cable to gently remove it.
    • Slide flat cable out of socket.
  7. Asus X401A Hard Drive Replacement, Hard drive screws: 7 단계, 이미지 1/1
    • Remove 2 screws
  8. Asus X401A Hard Drive Replacement, Physically removing the hard drive: 8 단계, 이미지 1/3 Asus X401A Hard Drive Replacement, Physically removing the hard drive: 8 단계, 이미지 2/3 Asus X401A Hard Drive Replacement, Physically removing the hard drive: 8 단계, 이미지 3/3
    • Using a finger you can now slide the hard drive out
결론
다른 7명이 해당 안내서를 완성하였습니다.
Eddie
회원 가입일: 09/19/15
315 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 32
전체 시간: 4,678
