주요 콘텐츠로 건너뛰기
Asus X401A Processor Replacement
필요한 것
  1. Asus X401A Processor Replacement, Processor: 1 단계, 이미지 1/2 Asus X401A Processor Replacement, Processor: 1 단계, 이미지 2/2
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: 2 단계, 이미지 1/3 Asus X401A Processor Replacement: 2 단계, 이미지 2/3 Asus X401A Processor Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: 3 단계, 이미지 1/3 Asus X401A Processor Replacement: 3 단계, 이미지 2/3 Asus X401A Processor Replacement: 3 단계, 이미지 3/3
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: 4 단계, 이미지 1/3 Asus X401A Processor Replacement: 4 단계, 이미지 2/3 Asus X401A Processor Replacement: 4 단계, 이미지 3/3
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: 5 단계, 이미지 1/1
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: 6 단계, 이미지 1/1
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: 7 단계, 이미지 1/2 Asus X401A Processor Replacement: 7 단계, 이미지 2/2
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: 8 단계, 이미지 1/1
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: 9 단계, 이미지 1/3 Asus X401A Processor Replacement: 9 단계, 이미지 2/3 Asus X401A Processor Replacement: 9 단계, 이미지 3/3
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: 10 단계, 이미지 1/2 Asus X401A Processor Replacement: 10 단계, 이미지 2/2
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: 11 단계, 이미지 1/2 Asus X401A Processor Replacement: 11 단계, 이미지 2/2
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: 12 단계, 이미지 1/3 Asus X401A Processor Replacement: 12 단계, 이미지 2/3 Asus X401A Processor Replacement: 12 단계, 이미지 3/3
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tyler Stiles
회원 가입일: 02/07/17
152 평판
안내서 1개 작성함
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017 회원
OSU-WILDER-S17S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 18
전체 시간: 1,830
