주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X401A RAM Replacement
필요한 것
  1. Asus X401A RAM Replacement, RAM: 1 단계, 이미지 2개 중 1개 Asus X401A RAM Replacement, RAM: 1 단계, 이미지 2개 중 2개
    • Before beginning your repair, unplug and turn off laptop to avoid risk of electric shock.
    • Turn laptop over and remove battery by sliding latches, and pulling up and out.
  2. Asus X401A RAM Replacement: 2 단계, 이미지 2개 중 1개 Asus X401A RAM Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Using a Phillips Head #1 screwdriver, unscrew ten screws from the back of the laptop.
    • Eight screws are 3mm.
    • Two screws are 4mm. Place screws on magnetic mat.
  3. Asus X401A RAM Replacement: 3 단계, 이미지 2개 중 1개 Asus X401A RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Pry open computer using plastic opening tool. You will be separating the keyboard from the back of the computer.
    • Do not completely separate the keyboard and back of the laptop. There are ribbon cables that need to be disconnected first.
    • When reassembling, you will hear snapping noise as you press the keyboard and back of the computer together.
  4. Asus X401A RAM Replacement: 4 단계, 이미지 2개 중 1개 Asus X401A RAM Replacement: 4 단계, 이미지 2개 중 2개
    • There are two ribbon cables connecting the keyboard to the motherboard.
    • The larger cable is a ZIF (Zero Insertion Force) cable. As the name implies, you do not need to use force to insert or disconnect this cable. Disconnect this ribbon cable by unlocking the holding latch and pulling out gently.
    • The smaller ribbon cable requires nothing more than pulling it out gently.
  5. Asus X401A RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the red, black, and white wires connecting the speakers by pulling gently.
  6. Asus X401A RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Using a Phillips Head #1 screwdriver, unscrew the seven 3 mm screws holding the motherboard in place. These are marked with white arrows on the motherboard (not shown in image).
    • Remove the two 3 mm screws holding the fan in place
  7. Asus X401A RAM Replacement: 7 단계, 이미지 3개 중 1개 Asus X401A RAM Replacement: 7 단계, 이미지 3개 중 2개 Asus X401A RAM Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the two 3mm screws holding the USB and charging port on the frame.
    • Disconnect the USB and charging port from the motherboard. There will be a ribbon cable as well as some wires to disconnect. Use a spudger if necessary.
  8. Asus X401A RAM Replacement: 8 단계, 이미지 3개 중 1개 Asus X401A RAM Replacement: 8 단계, 이미지 3개 중 2개 Asus X401A RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Use the spudger to lift the connection between the screen and motherboard.
    • You may be able to lift this connector without removing the yellow tape, but if it is in the way, removing it will not harm the laptop.
  9. Asus X401A RAM Replacement: 9 단계, 이미지 3개 중 1개 Asus X401A RAM Replacement: 9 단계, 이미지 3개 중 2개 Asus X401A RAM Replacement: 9 단계, 이미지 3개 중 3개
    • Use spudger to lift motherboard, frame, and fan.
    • Once lifted gently pull the motherboard to the left to remove the ports on the right side from the frame.
    • Set the frame aside and turn over the motherboard.
  10. Asus X401A RAM Replacement: 10 단계, 이미지 3개 중 1개 Asus X401A RAM Replacement: 10 단계, 이미지 3개 중 2개 Asus X401A RAM Replacement: 10 단계, 이미지 3개 중 3개
    • Release tension brackets on both sides of RAM and slide it up and out at a 45 degree angle.
    • When reassembling, slide RAM in as far you can at a 45 degree angle and snap it down into place.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Lesley Pfening
회원 가입일: 02/07/17
360 평판
안내서 2개를 작성함
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017 회원
OSU-WILDER-S17S1G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 68
전체 시간: 2,456
