주요 콘텐츠로 건너뛰기
Asus X401A Trackpad Replacement
필요한 것
  1. Asus X401A Trackpad Replacement, Trackpad: 1 단계, 이미지 1/2 Asus X401A Trackpad Replacement, Trackpad: 1 단계, 이미지 2/2
    • Working on your device while it is turned on may result in electric shock. Shut down and unplug your device before starting repair.
    • Turn over laptop and remove the battery for ease of replacement.
  2. Asus X401A Trackpad Replacement: 2 단계, 이미지 1/3 Asus X401A Trackpad Replacement: 2 단계, 이미지 2/3 Asus X401A Trackpad Replacement: 2 단계, 이미지 3/3
    • Use a Phillips Head #1 screwdriver to unscrew the eight 3mm screws.
    • Use a Phillips head #1 screwdriver to unscrew the two 4mm screws.
  3. Asus X401A Trackpad Replacement: 3 단계, 이미지 1/3 Asus X401A Trackpad Replacement: 3 단계, 이미지 2/3 Asus X401A Trackpad Replacement: 3 단계, 이미지 3/3
    • Use a plastic spudger to pry off the front cover of the keyboard.
    • Do not jerk the keyboard cover off as there are ribbon cables that need to be disconnected.
    • When reassembling, there will be loud clicking to indicate you have snapped the keyboard cover into place correctly.
  4. Asus X401A Trackpad Replacement: 4 단계, 이미지 1/2 Asus X401A Trackpad Replacement: 4 단계, 이미지 2/2
    • Removing the white wiring from the trackpad.
    • Continue removing the wire until you get to the end.
    • Fold up the latch on the where the cable meets the motherboard.
    • Be careful not to damage any wiring during this process.
    • When reassembling, slide ribbon cable in up to black line.
  5. Asus X401A Trackpad Replacement: 5 단계, 이미지 1/2 Asus X401A Trackpad Replacement: 5 단계, 이미지 2/2
    • Use a spudger to lift the ZIF connector tabs up.
    • Remove the black and the white ribbon cable.
    • Remove the entire keyboard covering.
  6. Asus X401A Trackpad Replacement: 6 단계, 이미지 1/1
    • Lay the keyboard cover down with the keys facing down. This component contains the track pad. You will be working with this component until you reassemble.
  7. Asus X401A Trackpad Replacement: 7 단계, 이미지 1/1
    • Begin peeling up the clear tape located on top of the band aid seal.
  8. Asus X401A Trackpad Replacement: 8 단계, 이미지 1/2 Asus X401A Trackpad Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Using a PH0 Phillips Screwdriver, remove the two screws located within the circles of the band aid seal.
    • These screws are small. Be sure to place them on your magnetic mat.
  9. Asus X401A Trackpad Replacement: 9 단계, 이미지 1/2 Asus X401A Trackpad Replacement: 9 단계, 이미지 2/2
    • Begin peeling back the band aid tape. Use the plastic spudger if necessary. This will allow you to free up the trackpad.
    • Only pull the tape back to the seam and no further.
  10. Asus X401A Trackpad Replacement: 10 단계, 이미지 1/2 Asus X401A Trackpad Replacement: 10 단계, 이미지 2/2
    • Remove the faulty trackpad gently.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lesley Pfening
회원 가입일: 02/07/17
360 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017 회원
OSU-WILDER-S17S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 1,061
