주요 콘텐츠로 건너뛰기
Asus X502CA-BCL0901D Battery Replacement
필요한 것
  1. Asus X502CA-BCL0901D Battery Replacement, Keyboard: 1 단계, 이미지 1/1
    • Flip the laptop over so that it is upside down.
  2. Asus X502CA-BCL0901D Battery Replacement: 2 단계, 이미지 1/1
    • Remove the 11 screws from the bottom of the laptop with the Phillips #00 screwdriver.
    • All the screws are 20 mm in diameter. The 4 screws that are furthest from the hinge are 50 mm long, the other 7 are 90 mm long.
  3. Asus X502CA-BCL0901D Battery Replacement: 3 단계, 이미지 1/2 Asus X502CA-BCL0901D Battery Replacement: 3 단계, 이미지 2/2
    • Use the Plastic Opening Tool to pry the keyboard assembly away from the rest of the laptop.
    • Take care not to lift the keyboard assembly to far away from the laptop as there are short cables that need to be disconnected first.
  4. Asus X502CA-BCL0901D Battery Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • While lifting the keyboard assembly, use the tweezers to gently remove the keyboard cable and the touch pad cable by pulling the wires away from the laptop base. Both cables must be gently but firmly pulled towards you for safe removal.
  5. Asus X502CA-BCL0901D Battery Replacement: 5 단계, 이미지 1/2 Asus X502CA-BCL0901D Battery Replacement: 5 단계, 이미지 2/2
    • Lift the keyboard assembly away from the remainder of the laptop.
  6. Asus X502CA-BCL0901D Battery Replacement, Battery: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Unplug the battery from the laptop with the tweezers.
    • If the battery is not unplugged, the motherboard may shock you.
  7. Asus X502CA-BCL0901D Battery Replacement: 7 단계, 이미지 1/2 Asus X502CA-BCL0901D Battery Replacement: 7 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, unscrew the 6 screws holding the battery in place.
    • Each screw is 50 mm in length and 15 mm in diameter.
  8. Asus X502CA-BCL0901D Battery Replacement: 8 단계, 이미지 1/1
    • Lift the battery out of the laptop.
결론
Gregory Browne
회원 가입일: 10/19/17
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S3-G5, Bailey Fall 2017 UMass Dartmouth, Team S3-G5, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G5
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 287
