주요 콘텐츠로 건너뛰기
Asus X540S notebook PC Hard drive Replacement
필요한 것
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S notebook PC Hard drive  Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S notebook PC Hard drive  Replacement: 3 단계, 이미지 3개 중 1개 Asus X540S notebook PC Hard drive  Replacement: 3 단계, 이미지 3개 중 2개 Asus X540S notebook PC Hard drive  Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
  3. Asus X540S notebook PC Hard drive  Replacement, Hard drive: 4 단계, 이미지 2개 중 1개 Asus X540S notebook PC Hard drive  Replacement, Hard drive: 4 단계, 이미지 2개 중 2개
    • Remove the one Philips #1 screw.
    • Slide the hard drive out.
  4. Asus X540S notebook PC Hard drive  Replacement: 5 단계, 이미지 2개 중 1개 Asus X540S notebook PC Hard drive  Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four Philips #1 screws.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Padraic Hoselton
회원 가입일: 08/22/17
4,339 평판
안내서 12개를 작성함
Apple tech Apple tech 회원
Community
1 회원
안내서 20개를 작성함
7가이드 댓글
Looks simple enough Padraic. Thanks. Does a new install of win10 come already copied in a new HDD? Would this replacement be and different if I used a digital drive? (My old hd failed and I have no system).
sludge - 답글
After installing an OEM replacement HDD in my x540, I bought a flash drive on Amazon for$10 that rebooted my Windows 10 and it's working like a brand new machine.
I believe the product key for windows 10 is embedded in motherboard.
F S -
F S - 답글
Hi … How can a flashdrive reboot a Win10 on a new SDD /HDD ? A Windows flash drive contains a Win10 bootable ISO ?
On Amazon, I found flash drives with a product key but I don’t know where the new installation can be done from if there is no ISO on it …
(I have a x540 with a dead HDD …)
gnogno35 -
And thank you Padraic
F S - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 80
전체 시간: 14,938
