주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X550CA RAM Replacement
필요한 것
  1. Asus X550CA RAM Replacement, Turning off your Computer: 1 단계, 이미지 3개 중 1개 Asus X550CA RAM Replacement, Turning off your Computer: 1 단계, 이미지 3개 중 2개 Asus X550CA RAM Replacement, Turning off your Computer: 1 단계, 이미지 3개 중 3개
    • Please make sure that your computer is fully Shut Down, so that the lights on the bottom of the computer are all of (Picture 2) and the Power Cord is unplugged.
    댓글 쓰기
  2. Asus X550CA RAM Replacement, Unplugging the Battery: 2 단계, 이미지 3개 중 1개 Asus X550CA RAM Replacement, Unplugging the Battery: 2 단계, 이미지 3개 중 2개 Asus X550CA RAM Replacement, Unplugging the Battery: 2 단계, 이미지 3개 중 3개
    • Spread the 2 clips on each side of the battery out, the one on the right should lock, and you will need to hold the one on the left while you pull the battery out. See the pictures for more details.
    댓글 쓰기
  3. Asus X550CA RAM Replacement, Starting with the Screwdriver: 3 단계, 이미지 1개 중 1개
    • You now need to use a screwdriver. I use the PH00 head of the iFixit 64 Bit driver kit.
    • Shown is bits from the 54 bit driver kit, not sold anymore. you can now get the 64 bit kit only.
    댓글 쓰기
  4. Asus X550CA RAM Replacement, Unscrewing the User Accessible Area: 4 단계, 이미지 2개 중 1개 Asus X550CA RAM Replacement, Unscrewing the User Accessible Area: 4 단계, 이미지 2개 중 2개
    • There are 2 screws on each side of the bottom of the computer. These are above the bottom 2 feet. They are quite long.
    댓글 쓰기
  5. Asus X550CA RAM Replacement, Taking off the Bottom: 5 단계, 이미지 2개 중 1개 Asus X550CA RAM Replacement, Taking off the Bottom: 5 단계, 이미지 2개 중 2개
    • The bottom is held on by clips. Pull back and then up to remove the plastic shell.
    댓글 쓰기
  6. Asus X550CA RAM Replacement, Taking out the RAM: 6 단계, 이미지 3개 중 1개 Asus X550CA RAM Replacement, Taking out the RAM: 6 단계, 이미지 3개 중 2개 Asus X550CA RAM Replacement, Taking out the RAM: 6 단계, 이미지 3개 중 3개
    • To take out the RAM, locate the RAM Stick (SODIMM) towards the right of the computer. Spread the clips on either side of the stick and the RAM stick should pop up. You can then pull out, and replace.
    • To reinstall, insert the new RAM stick at a slight angle (about 45 degrees). Push in and down to seat the RAM Correctly. Then just install the back panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Leo Carr
회원 가입일: 10/19/15
373 평판
안내서 1개를 작성함
2가이드 댓글
What is maximum memory for an ASUS X550CA?
Ben Bullard - 답글 공유
Mine came standard with 8GB, and I found that one of the sticks was soldered to the motherboard. I think it only takes 8GB sticks, so therefore the maximum memory is 12GB.
Leo Carr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 69
전체 시간: 8,570
