필요한 것
Amongst the easiest of steps. Turn the laptop upside-down, with its lid on the work surface, with the battery facing you.
First, push the left latch from the right to the left. You can let go, as this latch holds its position, unlike the next one.
Then, push the right latch to the right. This latch has a spring, so keep it held.
Next, with the other hand, pull the battery out and back towards you.
Remove the two crazily-long screws from the bottom panel.
Then, push the panel forwards, away from you.
Remove the three short screws holding the HDD caddy down.
Pull the caddy to the right using the flap on the left of the caddy. The caddy will slide to the right.
Remove the five additional short screws from under the HDD/RAM panel.
Then remove each crazily-long screw at each corner of the bottom of the laptop.
Remove the two additional short screws from under where the battery was.
Next, use a guitar pick or the like to separate the palmrest from the base. As you can see, I chose to simply use my fingernails, as I have nothing else. I'd suggest avoiding the use of a flathead screwdriver.
Pick up the palmrest and shift it to the left just a bit, then put it down, so that it looks just like the picture.
Stick your fingernail under the black lock on J6201 (inside of the square in the picture), and then pull upwards gently.
Next, pull the cable out of the connector.
Lift the palmrest slowly and carefully, and look inside. Don't worry, there probably aren't any jumping spiders hiding inside.
Git yo' fingas in there and disengage the lock for the touchpad cable, and then pull the cable out.
Pick up the palmrest again, slowly and gracefully, then move it downwards so that you see the keyboard connector, like in the picture.
Disengage the lock, then pull the keyboard cable out.
There are no more cables. You may lift the palmrest, and put it aside.
Remove the nine short screws circled in the picture.
Remove the Wi-Fi card antennas by pulling up on the connectors.
Remove the Wi-Fi card by pulling it away from its slot.
Remove the optical drive by sliding it to your right, and out.
Remove the power jack connection by pulling it back, away from the motherboard.
Remove the speaker connection the same way as the power jack connection.
Pull the motherboard towards you and to the right, slowly, and then we'll talk about the rest of it.
Pull the video cable tape up from the motherboard.
Pull the video cable back, away from you, firmly, making sure that you grab the tape with it. It will come out suddenly, so don't get scared.
Pull the LCD cable from the left speaker's plastic tabs holding it down.
Pull the Wi-Fi antenna cables from the right speaker.
Pry the speakers from their adhesive. Using a flathead screwdriver, work your way around the speakers. It won't look too pretty, don't worry about it.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Good morning sir;
I have an asus x550cc laptop that I want to upgrade; Can I replace the motherboard with a new one model x550 Jx?
