주요 콘텐츠로 건너뛰기
Asus X550ZA-SA100603E Hard Drive Replacement
필요한 것
  1. Asus X550ZA-SA100603E Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove all of the 10 bottom case screws.
    • Seven of them are 14 mm screws.
    • Three of them are 4 mm screws.
  2. Asus X550ZA-SA100603E Hard Drive Replacement: 2 단계, 이미지 1/1
    • After the screws are removed, gently turn the computer to its upright position and open up the computer flap.
    • It is important to do this gently, as these pieces are loose.
  3. Asus X550ZA-SA100603E Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pry open a gap between the keyboard and the lower piece using a spudger.
    • This will uncover all of the internals in the laptop itself.
  4. Asus X550ZA-SA100603E Hard Drive Replacement: 4 단계, 이미지 1/1
    • Slide the hard drive out of its position to allow room for the new one.
    • Make certain the area is clean and no debris got into the slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Paul Flynn
회원 가입일: 01/14/19
16 평판
안내서 2개 작성하였습니다
IUPUI, Team S5-G5, Wilson Spring 2019 IUPUI, Team S5-G5, Wilson Spring 2019 회원
IUPUI-WILSON-S19S5G5
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 422
