주요 콘텐츠로 건너뛰기
Asus X550ZA-SA100603E RAM Replacement
  1. Asus X550ZA-SA100603E RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them. Make sure to keep the screws for reassembly.
  2. Asus X550ZA-SA100603E RAM Replacement: 2 단계, 이미지 1/1
    • Carefully turn the computer onto its bottom, and gently pull the bottom apart from the top.
  3. Asus X550ZA-SA100603E RAM Replacement: 3 단계, 이미지 1/1
    • Take a flathead driver, and gently pry open a gap between the keyboard and the lower piece. This should uncover the laptop's internals.
  4. Asus X550ZA-SA100603E RAM Replacement: 4 단계, 이미지 1/2 Asus X550ZA-SA100603E RAM Replacement: 4 단계, 이미지 2/2
    • The motherboard is the big board on the left-hand side of the internals. Remove all bordering screws that hold the motherboard in place.
  5. Asus X550ZA-SA100603E RAM Replacement: 5 단계, 이미지 1/2 Asus X550ZA-SA100603E RAM Replacement: 5 단계, 이미지 2/2
    • Carefully flip the motherboard over to expose the bottom of the board. You should find the RAM slots located on the right-hand side of the bottom of the motherboard.
  6. Asus X550ZA-SA100603E RAM Replacement: 6 단계, 이미지 1/1
    • Take two fingers and pull the securing slots outward. The RAM stick should easily pop out. Take the old stick out, and carefully put the new one in the slot. Push until you hear a clicking noise.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Paul Flynn
회원 가입일: 01/14/19
16 평판
안내서 2개 작성하였습니다
IUPUI, Team S5-G5, Wilson Spring 2019 IUPUI, Team S5-G5, Wilson Spring 2019 회원
IUPUI-WILSON-S19S5G5
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 334
