주요 콘텐츠로 건너뛰기
Asus X5511M-RCLN03 Battery Replacement
필요한 것
  1. Asus X5511M-RCLN03 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Battery Replacement: 2 단계, 이미지 1/1
    • Remove all 4 mm screws using a #00 Philip's screwdriver.
  3. Asus X5511M-RCLN03 Battery Replacement: 3 단계, 이미지 1/1
    • Open the laptop with the keyboard facing upward.
  4. Asus X5511M-RCLN03 Battery Replacement: 4 단계, 이미지 1/1
    • Carefully pry up the keyboard cover with your fingers or with a plastic spudger.
  5. Asus X5511M-RCLN03 Battery Replacement: 5 단계, 이미지 1/2 Asus X5511M-RCLN03 Battery Replacement: 5 단계, 이미지 2/2
    • Remove electrical ribbons by gently lifting up the tab that is holding them down, then pulling them gently.
  6. Asus X5511M-RCLN03 Battery Replacement: 6 단계, 이미지 1/1
    • Set the keyboard plate aside. Gently lift up battery to remove it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ryann Easterbrook
회원 가입일: 01/12/17
154 평판
안내서 1개 작성함
Oakland University, Team 2-5, Ruskiewicz Winter 2017 Oakland University, Team 2-5, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G5
3 회원들
안내서 2개 작성하였습니다
댓글 3개
Peer review:
Step 1: This step is unclear and seems unnecessary. It should be removed or reworded to be more specific: "Position the laptop with the back cover facing upward."
Step 3: This step is also unclear and seems unnecessary. It should be removed or reworded: "Re-position the laptop with the back cover facing downward."
Step 5: This step is grammatically confusing and should be reworded. Example: "Lift up the tab covering the electrical ribbons. Pull the ribbons gently to remove them."
Courtney Clark - 답글
Steps 5 and 6 are missing photos so the instruction is not clear.
Courtney Clark - 답글
This was a easy and strait forward repair it took longer to find the tools than to do the repair. The hardest part for me was plugging the flex cables back in as I have a tremor in my hands. the repair took about 10 minutes.
DANIEL HATHAWAY - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,587
