주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The front display bezel holds the LCD screen to the base of the laptop.
  1. Power off and unplug your laptop before you begin.
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Invert the laptop in order to gain access to the ribbons. Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon. Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  7. Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  8. Once it is free, remove the hard drive from its internal cavity.
    • Once it is free, remove the hard drive from its internal cavity.
  9. Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
  10. Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
  11. Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
  12. Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
  13. Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
  14. Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
  15. With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
  16. Now, locate the two wires connected to the motherboard. Now, locate the two wires connected to the motherboard.
    • Now, locate the two wires connected to the motherboard.
  17. Remove the wires by easily pulling them parallel to the motherboard's surface. The wires are very fragile. Be sure to pull carefully so that they do not break!
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
  18. Remove the LCD display connection by gently pulling on the attached wire. Gently lift any tape that may be holding the connection.
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
  19. Remove the motherboard from the case by gently lifting it upward.
    • Remove the motherboard from the case by gently lifting it upward.
  20. Locate both of the hinges that connect the monitor to the bottom plate cover.
    • Locate both of the hinges that connect the monitor to the bottom plate cover.
  21. Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge. Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
    • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
  22. Once the screws are removed, the monitor should easily lift away from the bottom plate cover
    • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
  23. Locate the two stickers that cover up the screws that hold the front bezel in place
    • Locate the two stickers that cover up the screws that hold the front bezel in place
  24. Use a pair of tweezers to remove these stickers. The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
    • Use a pair of tweezers to remove these stickers.
    • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
  25. Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
    • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
  26. Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
    • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
  27. Once the screws are taken out, the front bezel is ready to be removed. Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
    • Once the screws are taken out, the front bezel is ready to be removed.
    • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
    • Gently use hands if necessary to separate the front bezel from the back.
  28. Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
    • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Josh
회원 가입일: 2014년 04월 10일
2,847 평판
안내서 12개 작성하였습니다
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 회원
CPSU-REGAN-S14S7G22
5 회원들
안내서 15개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 3,725
