주요 콘텐츠로 건너뛰기
Asus X551CA Power Button Replacement
필요한 것
  1. Asus X551CA Power Button Replacement, Keyboard Plate Cover: 1 단계, 이미지 1/1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Power Button Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Power Button Replacement: 3 단계, 이미지 1/1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Power Button Replacement: 4 단계, 이미지 1/3 Asus X551CA Power Button Replacement: 4 단계, 이미지 2/3 Asus X551CA Power Button Replacement: 4 단계, 이미지 3/3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Power Button Replacement: 5 단계, 이미지 1/1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Power Button Replacement, Power Button: 6 단계, 이미지 1/1
    • Locate the power button in the corner of the keyboard plate cover.
    • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
  7. Asus X551CA Power Button Replacement: 7 단계, 이미지 1/1
    • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
  8. Asus X551CA Power Button Replacement: 8 단계, 이미지 1/1
    • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Josh
회원 가입일: 04/10/14
2,934 평판
안내서 12개 작성하였습니다
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 회원
CPSU-REGAN-S14S7G22
5 회원들
안내서 15개 작성하였습니다
댓글 한 개
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 35
전체 시간: 12,312
