주요 콘텐츠로 건너뛰기
Asus X555LA-SI305041 CD Drive Replacement
필요한 것
  1. Asus X555LA-SI305041 CD Drive Replacement, Keyboard Assembly: 1 단계, 이미지 1/1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041 CD Drive Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041 CD Drive Replacement: 3 단계, 이미지 1/1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041 CD Drive Replacement: 4 단계, 이미지 1/1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041 CD Drive Replacement: 5 단계, 이미지 1/1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
  6. Asus X555LA-SI305041 CD Drive Replacement, CD Drive: 6 단계, 이미지 1/1
    • Using a #0 Phillips screw driver, remove the (5mm) black screw to the left of the CD Drive and to the right of the cooling fan.
  7. Asus X555LA-SI305041 CD Drive Replacement: 7 단계, 이미지 1/1
    • CD Drive should easily slide out.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Alex Turner
회원 가입일: 09/28/15
1,843 평판
안내서 3개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 41
전체 시간: 7,443
