주요 콘텐츠로 건너뛰기
Asus X55C CMOS / BIOS Battery Replacement
필요한 것
동영상 개요
  1. Asus X55C CMOS / BIOS Battery Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Switch off the laptop and remove the battery.
  2. Asus X55C CMOS / BIOS Battery Replacement: 2 단계, 이미지 3개 중 1개 Asus X55C CMOS / BIOS Battery Replacement: 2 단계, 이미지 3개 중 2개 Asus X55C CMOS / BIOS Battery Replacement: 2 단계, 이미지 3개 중 3개
    • The Keyboard is held by 5x locking clips.
    • Pick up a little the one side of the Keyboard and start opening the clips one by one.
    • Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • Please SUBSCRIBE to my channel ツ
  3. Asus X55C CMOS / BIOS Battery Replacement, Optical Drive: 3 단계, 이미지 2개 중 1개 Asus X55C CMOS / BIOS Battery Replacement, Optical Drive: 3 단계, 이미지 2개 중 2개
    • Remove the screw.
    • Pull out the SATA DVD Drive.
  4. Asus X55C CMOS / BIOS Battery Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Asus X55C CMOS / BIOS Battery Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Remove 3x Philips screws.
    • Disconnect the two small flex cables:
    • Power On button flex cable
    • Touch pad flex cable
  5. Asus X55C CMOS / BIOS Battery Replacement: 5 단계, 이미지 3개 중 1개 Asus X55C CMOS / BIOS Battery Replacement: 5 단계, 이미지 3개 중 2개 Asus X55C CMOS / BIOS Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  6. Asus X55C CMOS / BIOS Battery Replacement: 6 단계, 이미지 2개 중 1개 Asus X55C CMOS / BIOS Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the two coaxial antenna cables from the Wi-Fi card.
    • Remove any Memory or Dummy card.
  7. Asus X55C CMOS / BIOS Battery Replacement: 7 단계, 이미지 3개 중 1개 Asus X55C CMOS / BIOS Battery Replacement: 7 단계, 이미지 3개 중 2개 Asus X55C CMOS / BIOS Battery Replacement: 7 단계, 이미지 3개 중 3개
    • The bottom cover is held by 10x Phillips screws. Remove them.
    • With a plastic tool separate the Upper cover and remove it.
  8. Asus X55C CMOS / BIOS Battery Replacement: 8 단계, 이미지 3개 중 1개 Asus X55C CMOS / BIOS Battery Replacement: 8 단계, 이미지 3개 중 2개 Asus X55C CMOS / BIOS Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect:
    • The Microphone cable
    • The LCD Display flex cable
    • Remove 3x Pillips screws.
    • Lift the board first from the right edge.
    • There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
  9. Asus X55C CMOS / BIOS Battery Replacement: 9 단계, 이미지 2개 중 1개 Asus X55C CMOS / BIOS Battery Replacement: 9 단계, 이미지 2개 중 2개
  10. Asus X55C CMOS / BIOS Battery Replacement, CMOS / BIOS Battery: 10 단계, 이미지 3개 중 1개 Asus X55C CMOS / BIOS Battery Replacement, CMOS / BIOS Battery: 10 단계, 이미지 3개 중 2개 Asus X55C CMOS / BIOS Battery Replacement, CMOS / BIOS Battery: 10 단계, 이미지 3개 중 3개
결론
다른 8명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
195,826 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,453개를 작성함
1가이드 댓글
I have an ASUS X555Y laptop. It has an internal battery but for the life of me I cannot find the CMOS battery. I've taken everything apart and looked underneath the motherboard too,where the CMOS seems to usually be. No sign of it. Am I still somehow overlooking it? Or do I just not have one? I read in my searching that some models just don't have one.
I can't figure out what else is causing my laptop to not get past the "Aptio Setup Utility"
MovieSign - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 42
전체 시간: 16,518
