주요 콘텐츠로 건너뛰기
Asus X55C HDD (Hard Disk Drive) Replacement
필요한 것
동영상 개요
  1. Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 1 단계, 이미지 3개 중 1개 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 1 단계, 이미지 3개 중 2개 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 1 단계, 이미지 3개 중 3개
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Asus X55C HDD (Hard Disk Drive) Replacement: 2 단계, 이미지 3개 중 1개 Asus X55C HDD (Hard Disk Drive) Replacement: 2 단계, 이미지 3개 중 2개 Asus X55C HDD (Hard Disk Drive) Replacement: 2 단계, 이미지 3개 중 3개
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  3. Asus X55C HDD (Hard Disk Drive) Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,826 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,453개를 작성함
1가이드 댓글
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
Chris Deiotte - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 31
전체 시간: 11,908
