주요 콘텐츠로 건너뛰기
Asus X751L Battery Replacement
필요한 것
  1. Asus X751L Battery Replacement, Keyboard: 1 단계, 이미지 1/1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: 3 단계, 이미지 1/3 Asus X751L Battery Replacement: 3 단계, 이미지 2/3 Asus X751L Battery Replacement: 3 단계, 이미지 3/3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: 5 단계, 이미지 1/2 Asus X751L Battery Replacement: 5 단계, 이미지 2/2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: 6 단계, 이미지 1/3 Asus X751L Battery Replacement: 6 단계, 이미지 2/3 Asus X751L Battery Replacement: 6 단계, 이미지 3/3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
John Enderton
회원 가입일: 02/02/17
576 평판
안내서 2개 작성하였습니다
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G2
4 회원들
안내서 5개 작성하였습니다
댓글 6개
Very nice, thank you !
anh
barzamjavel - 답글
very nice, thank you !
Anh
barzamjavel - 답글
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - 답글
Your instructions were easy to follow. Thank you!!!
theresa collet - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 46
전체 시간: 12,801
