주요 콘텐츠로 건너뛰기
Asus X751L Keyboard Replacement
필요한 것
  1. Asus X751L Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Keyboard Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Keyboard Replacement: 3 단계, 이미지 1/3 Asus X751L Keyboard Replacement: 3 단계, 이미지 2/3 Asus X751L Keyboard Replacement: 3 단계, 이미지 3/3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
결론
다른 3명이 해당 안내서를 완성하였습니다.
John Enderton
회원 가입일: 02/02/17
576 평판
안내서 2개 작성하였습니다
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G2
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
phil.kath4 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 27
전체 시간: 3,156
