주요 콘텐츠로 건너뛰기
Asus X751L Wireless Card Replacement
필요한 것
  1. Asus X751L Wireless Card Replacement, Keyboard: 1 단계, 이미지 1/1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Wireless Card Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Wireless Card Replacement: 3 단계, 이미지 1/3 Asus X751L Wireless Card Replacement: 3 단계, 이미지 2/3 Asus X751L Wireless Card Replacement: 3 단계, 이미지 3/3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1/1
    • Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
  5. Asus X751L Wireless Card Replacement: 5 단계, 이미지 1/1
    • Using your fingers, lightly lift up on the black and white antenna cords.
  6. Asus X751L Wireless Card Replacement: 6 단계, 이미지 1/1
    • With your fingers lightly pull the wireless card out of the slot.
    • Make sure to keep the card parallel with the motherboard when removing from the slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Matthew Martin
회원 가입일: 02/02/17
211 평판
안내서 1개 작성함
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G2
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I feel the existing WiFi card is not very good. Is there is better one I can get for the Asus X751L?
July 3, 2023.
cookbake2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 17
전체 시간: 2,237
