주요 콘텐츠로 건너뛰기
Asus X751MA-DH01TQ Web Cam Replacement
필요한 것
  1. Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: 1 단계, 이미지 1/2 Asus X751MA-DH01TQ  Web Cam Replacement, Web Cam: 1 단계, 이미지 2/2
    • Turn the laptop upside down and locate the ten screws that hold the plate cover.
    • Remove all ten screws using a 00 Phillips head screwdriver.
  2. Asus X751MA-DH01TQ  Web Cam Replacement: 2 단계, 이미지 1/2 Asus X751MA-DH01TQ  Web Cam Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, pry the keyboard off of the base of the laptop.
    • Lift up and remove the keyboard.
  3. Asus X751MA-DH01TQ  Web Cam Replacement: 3 단계, 이미지 1/3 Asus X751MA-DH01TQ  Web Cam Replacement: 3 단계, 이미지 2/3 Asus X751MA-DH01TQ  Web Cam Replacement: 3 단계, 이미지 3/3
    • Remove eight 4.4 Phillips #00 screws attached to the hinge.
    • Hold the screen so it wont fall over.
  4. Asus X751MA-DH01TQ  Web Cam Replacement: 4 단계, 이미지 1/3 Asus X751MA-DH01TQ  Web Cam Replacement: 4 단계, 이미지 2/3 Asus X751MA-DH01TQ  Web Cam Replacement: 4 단계, 이미지 3/3
    • Remove the stickers from the bottom left and right corners of the screen.
    • Use a 00 Phillips head screw driver to remove the four screws.
  5. Asus X751MA-DH01TQ  Web Cam Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to take the screen apart.
  6. Asus X751MA-DH01TQ  Web Cam Replacement: 6 단계, 이미지 1/2 Asus X751MA-DH01TQ  Web Cam Replacement: 6 단계, 이미지 2/2
    • Remove the two 4mm Phillips #00 screws attached to the webcam.
  7. Asus X751MA-DH01TQ  Web Cam Replacement: 7 단계, 이미지 1/3 Asus X751MA-DH01TQ  Web Cam Replacement: 7 단계, 이미지 2/3 Asus X751MA-DH01TQ  Web Cam Replacement: 7 단계, 이미지 3/3
    • Slowly pull up the webcam out of its slot, and begin to remove the wire.
  8. Asus X751MA-DH01TQ  Web Cam Replacement: 8 단계, 이미지 1/2 Asus X751MA-DH01TQ  Web Cam Replacement: 8 단계, 이미지 2/2
    • Continue to unravel the wire and peel the webcam wire sticker off.
  9. Asus X751MA-DH01TQ  Web Cam Replacement: 9 단계, 이미지 1/2 Asus X751MA-DH01TQ  Web Cam Replacement: 9 단계, 이미지 2/2
    • Once the sticker is peeled off pull the plug holding the webcam into the circuit board and the webcam is now disconnected.
결론
Darren Kim
회원 가입일: 09/18/18
657 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 165
