소개
If you're having trouble with your laptop turning on or holding a charge then you may need to change the battery. This guide will help you to replace the battery.
필요한 것
Turn the laptop upside down and locate the ten screws holding in the plate cover.
Remove all ten screws using a small Phillips head screwdriver.
거의 끝나갑니다!
결론
