주요 콘텐츠로 건너뛰기
Asus X751MA-DH01TQ Battery Replacement
필요한 것
  1. Asus X751MA-DH01TQ Battery Replacement, Battery: 1 단계, 이미지 1/2 Asus X751MA-DH01TQ Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the laptop upside down and locate the ten screws holding in the plate cover.
    • Remove all ten screws using a small Phillips head screwdriver.
  2. Asus X751MA-DH01TQ Battery Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to pry open and separate the keyboard from the plate cover carefully.
    • The actual keyboard will detach not the back cover.
  3. Asus X751MA-DH01TQ Battery Replacement: 3 단계, 이미지 1/2 Asus X751MA-DH01TQ Battery Replacement: 3 단계, 이미지 2/2
    • The battery contains wires connecting it to a circuit board. Slowly pull up and disconnect the wires from the board by pulling on the white tab.
  4. Asus X751MA-DH01TQ Battery Replacement: 4 단계, 이미지 1/2 Asus X751MA-DH01TQ Battery Replacement: 4 단계, 이미지 2/2
    • Remove the two 7mm screws holding the battery in place using a Phillips #00 screwdriver.
  5. Asus X751MA-DH01TQ Battery Replacement: 5 단계, 이미지 1/1
    • Carefully lift the battery up out of place.
결론
Lindsey Romero
회원 가입일: 09/18/18
174 평판
안내서 1개 작성함
University of North Texas, Team S4-G5, Raign Fall 2018 University of North Texas, Team S4-G5, Raign Fall 2018 회원
UNT-RAIGN-F18S4G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 21
전체 시간: 1,122
