주요 콘텐츠로 건너뛰기
Asus X751MA-DH01TQ Fan Replacement
필요한 것
  1. Asus X751MA-DH01TQ Fan Replacement, Fan: 1 단계, 이미지 1/2 Asus X751MA-DH01TQ Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Turn the laptop upside down.
    • Remove all ten screws using a 00 Phillips head screwdriver.
  2. Asus X751MA-DH01TQ Fan Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to take the keyboard off of the base.
    • Gently take off the keyboard from the base.
  3. Asus X751MA-DH01TQ Fan Replacement: 3 단계, 이미지 1/2 Asus X751MA-DH01TQ Fan Replacement: 3 단계, 이미지 2/2
    • Remove the two screws directly above the fan.
  4. Asus X751MA-DH01TQ Fan Replacement: 4 단계, 이미지 1/2 Asus X751MA-DH01TQ Fan Replacement: 4 단계, 이미지 2/2
    • Unscrew the 11 screws that hold the motherboard to the base of the computer with a 00 Phillips screwdriver.
  5. Asus X751MA-DH01TQ Fan Replacement: 5 단계, 이미지 1/2 Asus X751MA-DH01TQ Fan Replacement: 5 단계, 이미지 2/2
    • Remove the one screw on the right side of the motherboard that keeps the cd tray in place.
  6. Asus X751MA-DH01TQ Fan Replacement: 6 단계, 이미지 1/2 Asus X751MA-DH01TQ Fan Replacement: 6 단계, 이미지 2/2
    • Gently take the motherboard off the base and flip it over.
    • Remove the screws securing the fan to the motherboard.
  7. Asus X751MA-DH01TQ Fan Replacement: 7 단계, 이미지 1/2 Asus X751MA-DH01TQ Fan Replacement: 7 단계, 이미지 2/2
    • Remove the Phillips #00 screw that holds the fan to the motherboard.
  8. Asus X751MA-DH01TQ Fan Replacement: 8 단계, 이미지 1/2 Asus X751MA-DH01TQ Fan Replacement: 8 단계, 이미지 2/2
    • On the bottom of the motherboard, locate the wire plugged in and pull it out to completely detach the fan from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Darren Kim
회원 가입일: 09/18/18
657 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 15
전체 시간: 359
