주요 콘텐츠로 건너뛰기
Asus X751MA-DH01TQ Screen Replacement
필요한 것
  1. Asus X751MA-DH01TQ Screen Replacement, Screen: 1 단계, 이미지 1/2 Asus X751MA-DH01TQ Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Turn the laptop upside down.
    • Unscrew the 10 screws on the bottom of the laptop using a PH00 screwdriver bit.
  2. Asus X751MA-DH01TQ Screen Replacement: 2 단계, 이미지 1/3 Asus X751MA-DH01TQ Screen Replacement: 2 단계, 이미지 2/3 Asus X751MA-DH01TQ Screen Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to detach and take off the keyboard.
  3. Asus X751MA-DH01TQ Screen Replacement: 3 단계, 이미지 1/3 Asus X751MA-DH01TQ Screen Replacement: 3 단계, 이미지 2/3 Asus X751MA-DH01TQ Screen Replacement: 3 단계, 이미지 3/3
    • Remove the eight 5.5 Phillips #00 screws located at the top right and left hand side of panel.
    • There are four screws on each side.
  4. Asus X751MA-DH01TQ Screen Replacement: 4 단계, 이미지 1/3 Asus X751MA-DH01TQ Screen Replacement: 4 단계, 이미지 2/3 Asus X751MA-DH01TQ Screen Replacement: 4 단계, 이미지 3/3
    • Remove the four 4mm Phillips #00 screws on the bottom left and right of the screen.
    • There are two screws on each side.
  5. Asus X751MA-DH01TQ Screen Replacement: 5 단계, 이미지 1/1
    • Insert the plastic opening tool on the side of the screen and slide it all the way around to open the screen up.
  6. Asus X751MA-DH01TQ Screen Replacement: 6 단계, 이미지 1/3 Asus X751MA-DH01TQ Screen Replacement: 6 단계, 이미지 2/3 Asus X751MA-DH01TQ Screen Replacement: 6 단계, 이미지 3/3
    • Remove the cords on the left and right side of the screen.
  7. Asus X751MA-DH01TQ Screen Replacement: 7 단계, 이미지 1/3 Asus X751MA-DH01TQ Screen Replacement: 7 단계, 이미지 2/3 Asus X751MA-DH01TQ Screen Replacement: 7 단계, 이미지 3/3
    • Remove the eight total screws (4 on each side) that are on the side of the white part on the back of the screen.
  8. Asus X751MA-DH01TQ Screen Replacement: 8 단계, 이미지 1/3 Asus X751MA-DH01TQ Screen Replacement: 8 단계, 이미지 2/3 Asus X751MA-DH01TQ Screen Replacement: 8 단계, 이미지 3/3
    • Remove the two 4mm Phillips #00 screws on the top corners of the back of the screen.
    • Remove the metal bars that you have just unscrewed.
  9. Asus X751MA-DH01TQ Screen Replacement: 9 단계, 이미지 1/2 Asus X751MA-DH01TQ Screen Replacement: 9 단계, 이미지 2/2
    • Peel back the bronze sticker that is connecting the white border piece to the outside edge of the screen.
  10. Asus X751MA-DH01TQ Screen Replacement: 10 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the white part away from the screen.
  11. Asus X751MA-DH01TQ Screen Replacement: 11 단계, 이미지 1/2 Asus X751MA-DH01TQ Screen Replacement: 11 단계, 이미지 2/2
    • Pull the white part out and pull out the rest of the screen.
결론
Collen Bleigh
회원 가입일: 09/18/18
198 평판
안내서 1개 작성함
University of North Texas, Team S4-G5, Raign Fall 2018 University of North Texas, Team S4-G5, Raign Fall 2018 회원
UNT-RAIGN-F18S4G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 470
