소개
This guide will show how to replace the battery on an Asus Z54C-JS31 laptop. Over time batteries naturally lose their ability to hold a charge and will need to be replaced.
Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
Slide the switch on the top right corner to the right.
Slide and hold the switch on the top left corner to the left and carefully remove the battery.
다른 한 분이 해당 안내서를 완성하였습니다.
