소개
The display is vital to using a laptop. If the display is damaged or not functioning properly this guide will show how to replace it.
필요한 것
Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
Slide the switch on the top right corner to the right.
Slide and hold the switch on the top left corner to the left and carefully remove the battery.
거의 끝나갑니다!
결론
