주요 콘텐츠로 건너뛰기
Asus ZenBook Flip UX360C Keyboard Assembly Replacement
필요한 것
  1. Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Rubber Feet: 1 단계, 이미지 1/3 Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Rubber Feet: 1 단계, 이미지 2/3 Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Rubber Feet: 1 단계, 이미지 3/3
    • Turn laptop over.
    • Use the metal spudger to pry rubber feet off in the four corners of laptop.
  2. Asus ZenBook Flip UX360C Keyboard Assembly Replacement, Keyboard Assembly: 2 단계, 이미지 1/1
    • Flip device upside down, and remove the eleven 5 mm #1 Phillips case screws.
  3. Asus ZenBook Flip UX360C Keyboard Assembly Replacement: 3 단계, 이미지 1/1
    • Flip the device back over.
    • Insert an opening tool between the keyboard assembly and bottom casing, and slide it around the edge to pop the keyboard assembly free.
  4. Asus ZenBook Flip UX360C Keyboard Assembly Replacement: 4 단계, 이미지 1/1
    • Disconnect the keyboard ribbon cable from the motherboard.
결론
Kristopher Bright
회원 가입일: 03/30/22
397 평판
안내서 3개 작성하였습니다
IUPUI, Team 1-4, Harley Spring 2022 IUPUI, Team 1-4, Harley Spring 2022 회원
IUPUI-HARLEY-S22S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 15
전체 시간: 557
