주요 콘텐츠로 건너뛰기
Asus ZenBook Flip UX360C Solid State Drive Replacement
필요한 것
  1. Asus ZenBook Flip UX360C Solid State Drive Replacement, Solid State Drive: 1 단계, 이미지 1/1
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  2. Asus ZenBook Flip UX360C Solid State Drive Replacement: 2 단계, 이미지 1/1
    • Remove all eleven 5 mm Phillips #1 screws on the back cover.
  3. Asus ZenBook Flip UX360C Solid State Drive Replacement: 3 단계, 이미지 1/1
    • Use plastic opening tools to remove the keyboard panel.
  4. Asus ZenBook Flip UX360C Solid State Drive Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  5. Asus ZenBook Flip UX360C Solid State Drive Replacement: 5 단계, 이미지 1/1
    • Unscrew the 5 mm Phillips #1 retaining screw holding the SSD in place.
    • Carefully remove the SSD.
결론
Jeff Schuitema
회원 가입일: 09/23/19
313 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 52
전체 시간: 3,332
