주요 콘텐츠로 건너뛰기
Asus ZenBook UX303U Battery Replacement
필요한 것
  1. Asus ZenBook UX303U Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
  2. Asus ZenBook UX303U Battery Replacement: 2 단계, 이미지 1/1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
  3. Asus ZenBook UX303U Battery Replacement: 3 단계, 이미지 1/2 Asus ZenBook UX303U Battery Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool pry the back panel off of the laptop.
  4. Asus ZenBook UX303U Battery Replacement, Battery: 4 단계, 이미지 1/2 Asus ZenBook UX303U Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
  5. Asus ZenBook UX303U Battery Replacement: 5 단계, 이미지 1/2 Asus ZenBook UX303U Battery Replacement: 5 단계, 이미지 2/2
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Asus ZenBook UX303U Battery Replacement: 6 단계, 이미지 1/2 Asus ZenBook UX303U Battery Replacement: 6 단계, 이미지 2/2
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
  7. Asus ZenBook UX303U Battery Replacement: 7 단계, 이미지 1/2 Asus ZenBook UX303U Battery Replacement: 7 단계, 이미지 2/2
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Asus ZenBook UX303U Battery Replacement: 8 단계, 이미지 1/2 Asus ZenBook UX303U Battery Replacement: 8 단계, 이미지 2/2
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Asus ZenBook UX303U Battery Replacement: 9 단계, 이미지 1/1
    • Remove the speakers from the old battery.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Dean Anderson
회원 가입일: 02/14/18
630 평판
안내서 3개 작성하였습니다
USF Tampa, Team S3-G5, Nance Spring 2018 USF Tampa, Team S3-G5, Nance Spring 2018 회원
USFT-NANCE-S18S3G5
3 회원들
안내서 9개 작성하였습니다
댓글 11개
hello where I can buy a UX303U battery for asus?
jeannette dreifus - 답글
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
There are two screws holding the back panel in place. They are located below the two rubber pads at the back of the pc. They must be removed in order to open the back panel.
Dave Man - 답글
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Barny Harper - 답글
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
Barny Harper - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 32
30일 전: 100
전체 시간: 30,660
