이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If you need to replace the battery of your Asus ZenFone 2, follow this guide. Replacing the battery will require a good amount of work and time. Before you are able to get to the battery, you will first have to remove the bottom antennae.
필요한 것
Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
The black screws are 2.8 mm in length.
The silver screw is 5.5 mm in length.
Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
Put in a new battery and then reassemble your device by following these instructions in reverse order.
다른 83명이 해당 안내서를 완성하였습니다.
댓글 31개
Great job with excellent photographs and detailed explanations! Unfortunately this phone is a real goat rodeo when it comes to just replacing a battery. My phone froze and nothing seemed to help unlock it. Fortunately, I went back to an Android site and found the answer and was able to reboot it (holding the on/off button for 10-15 seconds) without trying to remove the battery. Thanks to you I've learned two valuable lessons.
my zenfone 2 charging very long time and berry laevel vry sort time discharge
shailendra - 답글
i replaced my Zenfone 2 ze551ml's battery carefully.
But when i put everything back ,it can not turn on .
the vibration motor is the only thing working
every few minutes the vibration will vibrate two times itself.
Can anyone tell me how to solve this problem,thanks
Hi there I'm having the same problem with my phone, did you get any responses on how to fix the problem
