주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ZenFone 2 Disassembly
필요한 것
  1. Asus ZenFone 2 Disassembly, Removing the Back Cover: 1 단계, 이미지 2개 중 1개 Asus ZenFone 2 Disassembly, Removing the Back Cover: 1 단계, 이미지 2개 중 2개
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
    댓글 쓰기
  2. Asus ZenFone 2 Disassembly, Remove the Inner Cover Screws: 2 단계, 이미지 1개 중 1개
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
    댓글 쓰기
  3. Asus ZenFone 2 Disassembly, Remove the Inner Cover: 3 단계, 이미지 2개 중 1개 Asus ZenFone 2 Disassembly, Remove the Inner Cover: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
    댓글 쓰기
  4. Asus ZenFone 2 Disassembly, Remove the Speaker: 4 단계, 이미지 1개 중 1개
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 40명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Eduardo Nodarse
회원 가입일: 02/10/16
4,812 평판
안내서 5개를 작성함
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G5
4 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 58
전체 시간: 27,158
