주요 콘텐츠로 건너뛰기
Asus ZenFone 2 Motherboard Replacement
필요한 것
  1. Asus ZenFone 2 Motherboard Replacement, Removing the Back Cover: 1 단계, 이미지 1/2 Asus ZenFone 2 Motherboard Replacement, Removing the Back Cover: 1 단계, 이미지 2/2
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
  2. Asus ZenFone 2 Motherboard Replacement, Remove the Inner Cover Screws: 2 단계, 이미지 1/1
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
    The screw next to the camera with the sticker on (top middle on screen) was T4 not J00
    Matthew Hew - 답글
  3. Asus ZenFone 2 Motherboard Replacement, Remove the Inner Cover: 3 단계, 이미지 1/2 Asus ZenFone 2 Motherboard Replacement, Remove the Inner Cover: 3 단계, 이미지 2/2
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
  4. Asus ZenFone 2 Motherboard Replacement, Remove the Speaker: 4 단계, 이미지 1/1
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
  5. Asus ZenFone 2 Motherboard Replacement, Remove the Antenna: 5 단계, 이미지 1/2 Asus ZenFone 2 Motherboard Replacement, Remove the Antenna: 5 단계, 이미지 2/2
    • Use a plastic opening tool to gently pry up both ends of the antenna.
    • Carefully remove the antenna wire from the plastic keepers along the side. Note their position for reassembly.
    • The antenna connections can be easily bent out of shape. Be sure to lift from underneath the cable as shown.
    It is very important to lift it form underneath... The connector on the motherboard is very fragile.
    Guile - 답글
    Is there any way to actually replace the port? It got ripped off mine.
    Matthew George -
    I am wondering how to repair it, it got ripped off as well.
    matthewdukes -
    Hello Guile,
    I ripped the connector of gsm antenna on the other side (mainboard side) is there any way to fix it? It May be connect another contact point?
    Emrah AKBIYIK -
    same problem...solutions?
    Francesco Marra - 답글
    Same problem any solution?
    cecythebest - 답글
    Same problem too... :(
    Emrah AKBIYIK - 답글
    Is this wifi antenna?
    Dan Ramzi - 답글
  6. Asus ZenFone 2 Motherboard Replacement, Unlock Circuit Board Ribbon Cable: 6 단계, 이미지 1/2 Asus ZenFone 2 Motherboard Replacement, Unlock Circuit Board Ribbon Cable: 6 단계, 이미지 2/2
    • Using the plastic opening tool, unlock the ribbon cable attaching the battery to the circuit board by prying up the yellow tab.
  7. Asus ZenFone 2 Motherboard Replacement, Remove Vibration Motor: 7 단계, 이미지 1/1
    • Using a plastic opening tool, gently pry the vibration motor from its mount.
    This image is too dark and there is no marker to identify the vibration motor.
    Amanda Radakovich - 답글
  8. Asus ZenFone 2 Motherboard Replacement, Remove Circuit Board: 8 단계, 이미지 1/1
    • Gently remove the circuit board from the phone by gently pulling it away from the bottom of the phone.
    There´s some adhesive tape holding the ribbon cable on to the flat connector, it needs to be carefully raised before this board can be removed.
    Manny Faulborn - 답글
  9. Asus ZenFone 2 Motherboard Replacement, Disconnect Ribbon Cables: 9 단계, 이미지 1/2 Asus ZenFone 2 Motherboard Replacement, Disconnect Ribbon Cables: 9 단계, 이미지 2/2
    • Using the plastic opening tool, disconnect the ribbon cables from their connectors by gently prying them up.
    Suggest rotating the phone in your hand to better access the ribbon cables?
  10. Asus ZenFone 2 Motherboard Replacement, Remove the Battery: 10 단계, 이미지 1/1
    • Carefully remove the battery pack from the phone using your hand. The battery is glued in placed by a strip of adhesive on the top side so some force may be necessary.
    • There are fragile tabs on the left and right side of the battery, be careful not to break them off.
    The battery is glued in placed by a strip of adhesive on the top side so some force may be necessary. In my case the strip of adhesive is on the long right side of the battery.
    stavbin - 답글
  11. Asus ZenFone 2 Motherboard Replacement, Lift up the Copper Heat Strip: 11 단계, 이미지 1/3 Asus ZenFone 2 Motherboard Replacement, Lift up the Copper Heat Strip: 11 단계, 이미지 2/3 Asus ZenFone 2 Motherboard Replacement, Lift up the Copper Heat Strip: 11 단계, 이미지 3/3
    • Using a plastic opening tool, lift the copper sheet heat strip from the body of the phone by sticking the tool into one of the upper corner of the copper sheet and slowly sliding it along the edges.
    • Be careful not to rip the copper sheet.
  12. Asus ZenFone 2 Motherboard Replacement, Detach the Motherboard Ribbon Cable: 12 단계, 이미지 1/2 Asus ZenFone 2 Motherboard Replacement, Detach the Motherboard Ribbon Cable: 12 단계, 이미지 2/2
    • Using a plastic opening tool, unplug the ribbon cable indicated in the picture.
  13. Asus ZenFone 2 Motherboard Replacement, Detach the Screen Connector Ribbon Cable: 13 단계, 이미지 1/2 Asus ZenFone 2 Motherboard Replacement, Detach the Screen Connector Ribbon Cable: 13 단계, 이미지 2/2
    • Using a plastic opening tool, disconnect the display cable from the side of the motherboard by carefully sticking the tool underneath the display cable and gently pulling outward.
    The cable should not be pulled that way… you could damage it (I learned it the hard way). Pull up the metal shielding first then un-hatch the locking mechanism inside…
    tri5kmark - 답글
    Yes. I destroyed a motherboard like this. I guess that is what I get for listening to only one instruction.
    Paul Graham - 답글
  14. Asus ZenFone 2 Motherboard Replacement, Remove the Motherboard from the Retaining Clips: 14 단계, 이미지 1/3 Asus ZenFone 2 Motherboard Replacement, Remove the Motherboard from the Retaining Clips: 14 단계, 이미지 2/3 Asus ZenFone 2 Motherboard Replacement, Remove the Motherboard from the Retaining Clips: 14 단계, 이미지 3/3
    • There are four black plastic retainers, two on each side, that keep the motherboard fix in place. To get the motherboard out, stick a plastic opening tool under one top corner of the motherboard and carefully lift upward using a small amount of force to pop this side of the motherboard out of the plastic retainers.
    • Be careful not to break the black plastic retainers as these are needed to put the motherboard back in place.
    In the model Z00D there are only two clips.
    Arfor Houwman - 답글
  15. Asus ZenFone 2 Motherboard Replacement, Finish Removing the Motherboard: 15 단계, 이미지 1/1
    • Once one side of the motherboard is out of the black plastic retainers, remove the whole motherboard from the phone.
    • The motherboard should come out easily once one side of it is freed from the black plastic retainers.
결론
Put in a new motherboard and reassemble your device by following these instructions in reverse order.
다른 41명이 해당 안내서를 완성하였습니다.
Eduardo Nodarse
회원 가입일: 02/10/16
4,797 평판
안내서 5개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G5
4 회원들
안내서 16개 작성하였습니다
댓글 20개
Hi!I
After replacing the complete appliance front but the unit turns on but nothing appears on the screen, what may have happened?
horacildo - 답글
Check if the screen ribbon cable is firmly attached to the motherboard. If it is you may have a faulty motherboard replaced or a faulty screen
Nathan The Neko -
Thanks this helped a lot, Download Asus full firmware here: https://www.droidtechie.com/official-ful...
Sam Peter - 답글
Is there any place where I can order just the audio jack?
Sergio Lapunov - 답글
Is there a reliable source to buy a motherboard you can suggest? I need to replace the audio jack. Thank you for the neat guide.
sriram010689 - 답글
I want to buy asus zenfone 2 audio jack part..... Plz help me how to get my order
Ngams - 답글
On my unit the problem is not the audio jack itself but the soldering point that is broken. I contacted Asus for the part and they don't want to sell it...
Mathieu Chabot -
i want to buy zenfone 2 ze551ml motherboard please please help me where i can get it at low cost............ please inform me it`s urgent....
Gourav - 답글
how much is the board of asus zenfone 2? I accidentally drop mine in the sea while on vacation and my phone is shorted 100% and they said I have to replace the board and with that I also have to loose my files and pics. everything. thanks
Precy Ann Serafica - 답글
Hi i need a motherboard for asus ZenFone 2 z00ad how can i bye it.?
Arpan Maiti - 답글
hi..
how to identify the UEM of Asus 2 and Asus 6?
Ryan Villamil - 답글
Manoj Dhakre - 답글
Dopo che si e sostituisce la scheda madre ce bisogno di: installare i drive r il sistema operattivo?
Sandro - 답글
Quando viene acceso per la prima volta Dopo che ho installato la scheda madre cosa si deve fare?
Sandro - 답글
Hi i want to purchase Asus Zenfone laser 2 motherboard kindly help me.
+919838587378
Zinga Lala - 답글
hello Guys, I had to reset my Asus Zenfone 2 laser because of auto restarting which couldn’t reach the principle manager system. now I cannot access google account and phone manager. all my access stop at the setting, please kindly assist.
lankeu - 답글
Where we can get new motherboard of Asus zenfone 2 laser ze550kl
sujeet sinha - 답글
Hello will you help me were to asus zooad touchscreen bodyhousing.email mme rommeldp89@yahoo.com
Rommel Dela Peña - 답글
Please help me were to buy asus zooad touchscreen and bodyhousing email rommeldp89@yahoo.com
Is there any site where I can order Power IC for Asus Zenfone 2 Laser? or Motherboard for Zenfone 2 laser 3G/32G?
ener_30 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 41
전체 시간: 52,008
