소개
To begin with, replacing the vibration motor is not that hard. All you need is a JIS size 00 head screwdriver, and a prying tool. CAUTION: The screws from the back of the phone are small, so we recommend using a mat or paper to help keep the screws together and to prevent them from getting lost.
필요한 것
Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
The black screws are 2.8 mm in length.
The silver screw is 5.5 mm in length.
The screw next to the camera with the sticker on (top middle on screen) was T4 not J00
Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
Use a plastic opening tool to remove the vibration motor.
Use a plastic opening tool to unplug the vibration motor at the indicated location.
Plug in the new vibration motor, and then reassemble your device by following the instructions for steps 1-4 in reverse order.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
That's not a replacement... the final step is impossible => it will ripp the connector from the board.
I bought a replacement for the whole board, but it come without it, and i can"t put my old vibration motor on it... oh and the black square connector is present on the new part
Can l power on the phone without vibration motor and simcard reader
