필요한 것
1 단계 Charging Port
주의: 1-6 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Use a thin plastic tool to peel the back cover of the phone off. Once the plastic tool has begun to pry the back off, slide the plastic tool around the edges of the phone to separate the adhesive holding the back on. Once all edges of the phone are disconnected, lift the back cover off.
Using the plastic spudger, pry up the vibration motor starting at the top right. The motor is held down with adhesive, so some force may be required.
다른 한 분이 해당 안내서를 완성하였습니다.
