주요 콘텐츠로 건너뛰기
Asus ZenWatch 2 Battery Replacement
필요한 것
  1. Asus ZenWatch 2 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Asus ZenWatch 2 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Asus ZenWatch 2 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the four 3.5mm screws to detach the case using the T5 screwdriver.
  2. Asus ZenWatch 2 Battery Replacement: 2 단계, 이미지 2개 중 1개 Asus ZenWatch 2 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the spudger under the battery and lift to remove.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Moriah
회원 가입일: 02/20/17
811 평판
안내서 3개를 작성함
USF Tampa, Team S1-G1, Leahy Spring 2017 USF Tampa, Team S1-G1, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G1
3 회원들
안내서 10개를 작성함
13가이드 댓글
Where do you get the battery?
Mark Miser - 답글
Sir,
I own Zenwatch 2 and it is just 14 months old. I left it uncharged for months. Now it is not at all charging. In Service Centre, they said Asus did not send any replacement spares even to test what was wrong.
I am from Mumbai, India. Where can i purchase replacement Battery so that i can try? Please help me sir.
Vijaykumar S
Mumbai
vijai kumar - 답글
Hello I have ZenWatch 2 Battery WI502Q-SL-BD need help looking Replacement Battery
Angel Alfredo Grant - 답글
i used non original battery, link here. Compare here.
4spam - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 70
전체 시간: 18,387
