주요 콘텐츠로 건너뛰기
Asus ZenWatch 2 Motherboard Replacement
필요한 것
  1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
  2. Asus ZenWatch 2 Motherboard Replacement: 2 단계, 이미지 1/2 Asus ZenWatch 2 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the two 1.8mm silver screws using the PH00 screwdriver.
  3. Asus ZenWatch 2 Motherboard Replacement: 3 단계, 이미지 1/2 Asus ZenWatch 2 Motherboard Replacement: 3 단계, 이미지 2/2
    • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
  4. Asus ZenWatch 2 Motherboard Replacement: 4 단계, 이미지 1/2 Asus ZenWatch 2 Motherboard Replacement: 4 단계, 이미지 2/2
    • Pull up on the motherboard using tweezers to detach it from the watch.
결론
Andrew
회원 가입일: 02/20/17
314 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G1, Leahy Spring 2017 USF Tampa, Team S1-G1, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G1
3 회원들
안내서 10개 작성하였습니다
댓글 6개
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - 답글
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - 답글
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard -
Where can you purchase a replacement motherboard?
Tasha Kanahele - 답글
My zenfone wach 2 all function not showing please help me
Akhtar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 2,585
