소개
The Asus Zenbook UX21e has an easily replaceable battery. To successfully remove the battery, the back cover must be removed, along with the five screws holding the battery to the device. From their, the battery simply disconnects from the motherboard and can be pulled out.
필요한 것
Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
다른 4명이 해당 안내서를 완성하였습니다.
