주요 콘텐츠로 건너뛰기
Asus Zenbook UX303L Battery Replacement
필요한 것
  1. Asus Zenbook UX303L Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure your device is OFF before performing this procedure.
    • Remove the eight 3 mm long screws using a T5 Torx Screwdriver.
    • Remove the single 8 mm long screw using a T5 Torx screwdriver.
  2. Asus Zenbook UX303L Battery Replacement: 2 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Lift and remove the back cover.
    • If your case does not easily come free, you may need to remove screws under the plastic feet on the bottom case.
  3. Asus Zenbook UX303L Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws from the sides of the battery.
    • Use a Phillips #0 screwdriver to remove the single 6 mm screw in the center of the battery.
  4. Asus Zenbook UX303L Battery Replacement: 4 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery connector up out of its socket on the motherboard to disconnect it.
    • A plastic opening tool can help lift the connector out of its socket. Do not pry on the socket itself or you risk damaging the motherboard.
  5. Asus Zenbook UX303L Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the speaker by carefully pulling the speaker cable away from its socket on the motherboard.
  6. Asus Zenbook UX303L Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Deroute the speaker cable from the clips so the battery can be fully removed.
  7. Asus Zenbook UX303L Battery Replacement: 7 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Lift up and remove the battery and speakers from the device.
  8. Asus Zenbook UX303L Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the speakers from the old battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Aashray Nagpal
회원 가입일: 04/01/19
163 평판
안내서 1개를 작성함
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G6
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 56
지난 30일: 233
전체 시간: 11,910
