주요 콘텐츠로 건너뛰기
Asus Zenbook UX303L Cooling Fan Replacement
필요한 것
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: 2 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Cooling Fan Replacement: 2 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Cooling Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: 3 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Cooling Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: 4 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Cooling Fan Replacement: 4 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Cooling Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: 5 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Cooling Fan Replacement: 5 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Cooling Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: 6 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Cooling Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Gently lift and slide the cooling fan out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Bianka Castaneda
회원 가입일: 10/13/15
469 평판
안내서 2개를 작성함
Sam Houston State, Team 1-3, Blackburne Fall 2015 Sam Houston State, Team 1-3, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G3
3 회원들
안내서 4개를 작성함
댓글 3개
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - 답글
I wish you guys had included the part number for the cooling fan.
mhyson - 답글
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 24
전체 시간: 6,259
