주요 콘텐츠로 건너뛰기
Asus Zenbook UX303L RAM Replacement
필요한 것
  1. Asus Zenbook UX303L RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • Prior to installing RAM, it's good practice to ground yourself to avoid static discharge from damaging the internal components of the computer.
    • Avoid wearing static prone clothing or standing on carpet during the RAM replacement.
  2. Asus Zenbook UX303L RAM Replacement: 2 단계, 이미지 2개 중 1개 Asus Zenbook UX303L RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the eight 3 mm long screws on the bottom of the laptop along the parameter using a T5 Torx screwdriver.
    • Unscrew the one 8 mm long screw at the bottom of the laptop panel using a T5 Torx screwdriver.
    • Once all screws have been removed, carefully lift the bottom panel to reveal the RAM.
  3. Asus Zenbook UX303L RAM Replacement: 3 단계, 이미지 3개 중 1개 Asus Zenbook UX303L RAM Replacement: 3 단계, 이미지 3개 중 2개 Asus Zenbook UX303L RAM Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully pull apart the two clasps circled in red so that the RAM stick pops up.
    • Remove the stick of RAM from the SO-DIMM slot by gripping the edges of the RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Evan Parker
회원 가입일: 04/01/19
136 평판
안내서 1개를 작성함
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G6
3 회원들
안내서 7개를 작성함
댓글 한 개
This is incomplete. There are two screws more hidden behind the rubber support points (on the hinges side) of the computer.
And you need some adhesive to fix this rubber squares in place after you fix the lid in place.
Ochirosi Paul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 55
전체 시간: 3,937
