주요 콘텐츠로 건너뛰기
Asus Zenbook UX303L Speaker Replacement
필요한 것
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: 1 단계, 이미지 1개 중 1개
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully peel away the defective speakers from the battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan Snow
회원 가입일: 04/01/19
202 평판
안내서 1개를 작성함
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G6
3 회원들
안내서 7개를 작성함
댓글 한 개
Is the Asus UX303L same as U303L?
Michael Wolf - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 37
전체 시간: 1,915
