주요 콘텐츠로 건너뛰기
Asus Zenbook UX303L Trackpad Replacement
필요한 것
  1. Asus Zenbook UX303L Trackpad Replacement, Trackpad: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Trackpad Replacement: 2 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 2 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Trackpad Replacement: 2 단계, 이미지 3개 중 3개
    • Remove all nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Trackpad Replacement: 3 단계, 이미지 1개 중 1개
    • Remove five Phillips #1 screws from the battery pack.
  4. Asus Zenbook UX303L Trackpad Replacement: 4 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 4 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Trackpad Replacement: 4 단계, 이미지 3개 중 3개
    • Unhook the red, black, and white coiled switch.
    • Detach the positive and negative red, black, yellow, and white switch from the motherboard.
    • Unhook the black and white coiled wire from the top of the battery pack.
  5. Asus Zenbook UX303L Trackpad Replacement: 5 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 5 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Trackpad Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the three screws connecting the SSD to the motherboard.
    • Gently lift and pull out the SSD.
  6. Asus Zenbook UX303L Trackpad Replacement: 6 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 6 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Trackpad Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the screw attaching the cooling fan to the motherboard.
    • Lift and remove the cooling fan.
  7. Asus Zenbook UX303L Trackpad Replacement: 7 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the four Phillips #1 screws attached to the black covered copper bar next to the cooling fan.
    • Gently lift and remove the copper bar.
  8. Asus Zenbook UX303L Trackpad Replacement: 8 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 8 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Trackpad Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the silver tape to reveal the fourth screw on the motherboard.
    • Detach the motherboard by removing the four Phillips #1 screws.
    • Detach the white wire connecting the motherboard by lifting the black flap and pulling it out.
  9. Asus Zenbook UX303L Trackpad Replacement: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • By using ESD-safe tweezers, remove the gray colored wire.
    • Remove the white wire using tweezers.
    • Remove the blue colored wire by lifting the black flap and pulling the blue flap out.
  10. Asus Zenbook UX303L Trackpad Replacement: 10 단계, 이미지 3개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 10 단계, 이미지 3개 중 2개 Asus Zenbook UX303L Trackpad Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the white wire with the blue ends by lifting the black flap with tweezers and gently pulling out.
    • Gently remove the silver tape using tweezers.
    • Remove the Phillips #1 screws.
  11. Asus Zenbook UX303L Trackpad Replacement: 11 단계, 이미지 2개 중 1개 Asus Zenbook UX303L Trackpad Replacement: 11 단계, 이미지 2개 중 2개
    • Place the plastic opening tools under the trackpad.
    • Gently pull out and remove the trackpad.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Fredis Benitez
회원 가입일: 10/13/15
259 평판
안내서 1개를 작성함
Sam Houston State, Team 1-3, Blackburne Fall 2015 Sam Houston State, Team 1-3, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G3
3 회원들
안내서 4개를 작성함
댓글 한 개
This laptop comes with a very bad trackpad, it has very low resolution. Do you think it can be updated?
eduugr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 27
전체 시간: 6,103
