주요 콘텐츠로 건너뛰기
Asus Zenbook UX31A Daughterboard Replacement
필요한 것
  1. Asus Zenbook UX31A Daughterboard Replacement, Battery: 1 단계, 이미지 1/2 Asus Zenbook UX31A Daughterboard Replacement, Battery: 1 단계, 이미지 2/2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Daughterboard Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Daughterboard Replacement: 3 단계, 이미지 1/1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Daughterboard Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Daughterboard Replacement, Fan: 5 단계, 이미지 1/2 Asus Zenbook UX31A Daughterboard Replacement, Fan: 5 단계, 이미지 2/2
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Daughterboard Replacement: 6 단계, 이미지 1/3 Asus Zenbook UX31A Daughterboard Replacement: 6 단계, 이미지 2/3 Asus Zenbook UX31A Daughterboard Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Daughterboard Replacement: 7 단계, 이미지 1/2 Asus Zenbook UX31A Daughterboard Replacement: 7 단계, 이미지 2/2
    • Disconnect the fan connector by puling on it horizontally until it disconnects.
    • Remove the fan.
  8. Asus Zenbook UX31A Daughterboard Replacement, Daughterboard: 8 단계, 이미지 1/1
    • Use tweezers to detach the cable from the board by pulling them gently toward the bottom edge of the board.
  9. Asus Zenbook UX31A Daughterboard Replacement: 9 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 6 mm screw that secures the daughterboard.
  10. Asus Zenbook UX31A Daughterboard Replacement: 10 단계, 이미지 1/1
    • Remove by carefully lifting the board from the laptop.
결론
Sherwin
회원 가입일: 03/22/22
209 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G1
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 164
