주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Zenbook UX31A Touchpad Replacement
필요한 것
  1. Asus Zenbook UX31A Touchpad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Asus Zenbook UX31A Touchpad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Touchpad Replacement: 3 단계, 이미지 1개 중 1개
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Touchpad Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Touchpad Replacement, Touchpad: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove all four 6 mm screws from the trackpad.
  6. Asus Zenbook UX31A Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Use your fingers or a nylon spuder to gently lift the track pad ZIF tab, and pull the ribbon cable free.
    • Be gentle with this wire since it is fragile
  7. Asus Zenbook UX31A Touchpad Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up and pull backwards to remove the touchpad
결론
작성자
2다른 기여자 명과 함께
Christopoher Orser
회원 가입일: 03/22/22
306 평판
안내서 2개를 작성함
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G1
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 69
전체 시간: 1,254
