주요 콘텐츠로 건너뛰기
Asus Zenbook UX31A Wi-Fi Card Replacement
필요한 것
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1/2 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2/2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Asus Zenbook UX31A Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: 3 단계, 이미지 1/1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by pulling up gently on each of them.
    • They can be a little tricky to put back on so take your time and be gentle.
결론
Sherwin
회원 가입일: 03/22/22
209 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G1
5 회원들
안내서 8개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 129
