주요 콘텐츠로 건너뛰기
Asus Zenbook UX31E Battery Replacement
필요한 것
  1. Asus Zenbook UX31E Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Battery Replacement: 2 단계, 이미지 1/1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Battery Replacement, Battery: 3 단계, 이미지 1/2 Asus Zenbook UX31E Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E Battery Replacement: 4 단계, 이미지 1/2 Asus Zenbook UX31E Battery Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E Battery Replacement: 5 단계, 이미지 1/2 Asus Zenbook UX31E Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
결론
다른 5명이 해당 안내서를 완성하였습니다.
Hersi Dahir
회원 가입일: 02/02/17
203 평판
안내서 1개 작성함
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017 회원
UWT-ROSE-W17S1G2
4 회원들
안내서 9개 작성하였습니다
댓글 2개
Thanks for the easy to understand guide. Cheers!
Rahul Kashelani - 답글
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
fiddyfadhlina - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 32
전체 시간: 7,899
