필요한 것
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Thanks for the easy to understand guide. Cheers!
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
Can you tell me what size these screws are? I need to replace two.
Elliot Lozano - 답글
I don’t know, but you can search with product code: VISTORXUX31E
See also: https://en.accessoires-asus.com/torx-scr...|l
Davide Bortot -
