주요 콘텐츠로 건너뛰기
Asus Zenbook UX31E Fan Replacement
필요한 것
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: 2 단계, 이미지 1/1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: 3 단계, 이미지 1/2 Asus Zenbook UX31E Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: 4 단계, 이미지 1/1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: 5 단계, 이미지 1/2 Asus Zenbook UX31E Fan Replacement: 5 단계, 이미지 2/2
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: 6 단계, 이미지 1/2 Asus Zenbook UX31E Fan Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
결론
Sinh
회원 가입일: 02/01/17
101 평판
안내서 1개 작성함
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017 회원
UWT-ROSE-W17S1G2
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 1,724
