필요한 것
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
At the marked locations, unscrew 7 screws with your Phillips 00 Precision Screwdriver.
At the marked locations (under certain components), unscrew 3 screws with your Phillips 00 Precision Screwdriver.
다른 5명이 해당 안내서를 완성하였습니다.
