주요 콘텐츠로 건너뛰기
Asus Zenbook UX31E Speaker Replacement
필요한 것
  1. Asus Zenbook UX31E Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Speaker Replacement: 2 단계, 이미지 1/1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  4. Asus Zenbook UX31E Speaker Replacement: 4 단계, 이미지 1/2 Asus Zenbook UX31E Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  5. Asus Zenbook UX31E Speaker Replacement: 5 단계, 이미지 1/2 Asus Zenbook UX31E Speaker Replacement: 5 단계, 이미지 2/2
    • Disconnect the sound cable from the motherboard.
  6. Asus Zenbook UX31E Speaker Replacement: 6 단계, 이미지 1/2 Asus Zenbook UX31E Speaker Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, pry open the speaker component from the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zachary Somerscales
회원 가입일: 02/02/17
146 평판
안내서 1개 작성함
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017 회원
UWT-ROSE-W17S1G2
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 2,773
